Thread: hot gas defrost valve
21-10-2007, 08:16 PM #1
hi - I was wondering could some one inform me of the exact usage of a hot gas defrost valve on a R22 system and the also if there is a relative info in changing one?
21-10-2007, 11:18 PM #2
Re: hot gas defrost valve
Hi shills33
a hot gas valve is a generic term, could be a solinoide used to let hot gas in or a pressure regulating valve to raise/control the hot gas pressure to a level at which ice will melt off the coil (usually about a pressure of about 10 deg c)
Hope this helps.
Kind Regards AndyIf you can't fix it leave it that no one else will:rolleyes:
31-10-2007, 11:45 PM #3
The other thing about change. Just remember to be prepare to recovery all R-22 , usually that valve is in the discharge line.
02-11-2007, 07:01 PM #4
Hot gas defrost
By chillyblue in forum Trouble ShootingReplies: 6Last Post: 18-09-2007, 09:43 PM -
Hot gas defrost vs Electric defrost
By herdian in forum IndustrialReplies: 19Last Post: 13-08-2007, 11:25 PM -
Hot Gas vs. Electric Defrost
By herefishy in forum Technical DiscussionsReplies: 26Last Post: 08-03-2005, 07:50 PM -
TEV with MOP: how to keep valve body temp above bulb temp?
By DaBit in forum FundamentalsReplies: 5Last Post: 16-10-2002, 12:38 AM -
Hot gas defrost
By Volnei in forum FundamentalsReplies: 2Last Post: 18-05-2002, 12:26 PM
