Results 1 to 2 of 2
Thread: Evaporative Condenser
07-10-2007, 09:12 AM #1
Hi Everybody,
Can you pls give suggetion for the following doubts.
Evaporative condenser software is available only for R-22,R-134A,&R717.But it is not available for R404-A why?
Pls mention the weblink if available.
07-10-2007, 09:00 PM #2
Re: Evaporative Condenser
The manufacturers will usually tell you to use the correction factor for R-134a capacity as it is normally close enough.
I doubt there is sufficient market share to develop exact correction factors for every refrigerant.If all else fails, ask for help.
Evaporative Condenser in reverse cycle
By Friobernal in forum IndustrialReplies: 6Last Post: 16-04-2009, 02:06 PM -
Evaporative Condenser Presure Lost
By gwapa in forum NH3Replies: 9Last Post: 16-02-2008, 10:02 AM -
evaporative condenser
By Lc_shi in forum FundamentalsReplies: 16Last Post: 02-05-2006, 08:25 AM -
Evaporative condenser surface area
By Gonzalo Arias in forum FundamentalsReplies: 5Last Post: 06-08-2005, 11:27 PM -
Evaporative condenser pipe surface
By Gonzalo Arias in forum Tools and CalculatorsReplies: 0Last Post: 03-08-2005, 12:33 AM
