Results 1 to 9 of 9
Thread: EDC inverter check module
02-10-2007, 10:08 PM #1
Evening all..
Does anyone know if these are available over the counter in any of the usual trade suppliers? Need to pick one up sharpish for a job which is rapidly going very political, Thanks in advance
QS
02-10-2007, 10:12 PM #2
Re: EDC inverter check module
I think HRP do a inverter checker
CB
02-10-2007, 10:30 PM #3
A word of warning - don't leave it conected to power for more than 30 seconds as it tends to burn out the resistors.
I speak from experience
02-10-2007, 10:38 PM #4
RS components maybe?
i know this may not be very PC but if you are really in it,hows about using a 3 phase motor?Last edited by superswill; 02-10-2007 at 10:40 PM.
Paul
"KEEP IT COOL"
02-10-2007, 11:07 PM #5
EDC sell direct, maybe they will do a quick delivery service for you.
02-10-2007, 11:30 PM #6
Thanks guys -
probably try the over the counter approach first as need to prove to the client the fault is with the board rather than the pot. Maybe its just me but after concentrating on chillers and close control for the last 5 years its amazing how easy it is to come unstuck with the latest generation of splits (inverter driven and without the necessary fault code manuals real b1tches to diagnose)
QS
03-10-2007, 09:38 PM #7
Well managed to pick up one from walthamstow HRP this morning for about £30 = vat, Its the earlier model which wont check the serial link but no matter got the infomation i needed - the inverter pcb is U/S. Just out of interest though do the daikin RZQ R410A series not alarm to the indoor wired controller if the condensor is in fault with Red LED lit? Reset the unit on the outdoor isolator and put into fault (inverter) 5 times today and not once did i get an alarm on the indoor controller - think it used to be an E code on the earlier series units - any thoughts?
Andy
11-10-2007, 06:13 PM #8
if you want one for nothing come on any LG training course we will give you one free, we developed the inverter checker and serial tester with EDC to help engineers fix units easily. The instruction leaflet was written by me so if you cant understand it its all my fault sorry
go to www.mylg.co.uk and click training for details
see you soon
regards
Hendrag
09-12-2010, 10:29 AM #9
What would be the difference between the LG EDC and the standard Daikin Inverter Checker?
Daikin's is the normal 3 resistors, 3 capacitors and 6 LED's.
I have a CH22 problem which I have to go back to next week when they have cleared the ice enough for me to get proper "steps" access up to inverter PCB but when I popped in the other day this is the result I got with my standard inverter checker. The motor was not connected - this is the result with the UVW leads connected only to the inverter. Immediately before this test the compressor was managing 19 amps evenly on all phases.
http://www.youtube.com/watch?v=FzUu9g2jiDA
Not sure what the "gun shot" sounds are - I didn't hear them while filming - must be interference induced from the inverter to my mobile.Only the dogmatist says he will never change his mind. We all know that some of our opinions are wrong but none of us know which they are for if we did then they just wouldn't be our opinions. - JS Mill.
Testing Inverters
By fridge doctor in forum Air ConditioningReplies: 38Last Post: 15-06-2011, 06:52 AM -
daikin L0 inverter problem
By robin r33 gtr in forum Air ConditioningReplies: 17Last Post: 11-03-2010, 11:25 PM -
Inverter systems
By Latte in forum The Trail of TearsReplies: 23Last Post: 11-07-2007, 12:14 AM -
Air conditioning maintenance procedure
By Andy T in forum Air ConditioningReplies: 12Last Post: 27-05-2006, 06:57 PM -
Compressor Check for locked rotor voltage
By shogun7 in forum Trouble ShootingReplies: 0Last Post: 04-04-2004, 12:44 AM
