Thread: Suction Line Item
26-09-2007, 09:21 PM #1
Suction Line Item
Just installed a hitachi ras8 something (sorry dont know full model) but its a multi indoor system, with the suction line connection kit came a Large errrrr "pipe" if you like, to look at it looks like a drier but made of copper, its not a drier its just copper which expands then reduces again must expand to at least 1" 5/8 then reduce again, theres nothing init its just hollow if you like, what isit? and why have hitachi decided to use it? somthing to do with pressures? noise reduction?
cheers guys
26-09-2007, 10:30 PM #2
Re: Suction Line Item
It could be a Muffler or at least that's what it sounds like. Would be nice to see a picture to verify.
26-09-2007, 11:40 PM #3
I wonder if it is just a multi-size connector piece?
If you don't need the larger pipe size then connect directly, if you had used 1 5/8" then cut the end offf to fit.
Just guessingBrian - Newton Abbot, Devon, UK
27-09-2007, 09:22 AM #4
Hi SkyWalker
Noise control - possibly by damping pulsations of a certain frequency or minmising a resonant effect. Considering nothing inside more likely a small slug pot, to reduce a liquid or oil slug back to compressor. But hey I'm just guessing too. I'll check post later for more answers.
27-09-2007, 10:38 AM #5
hmm my guess is its a reducer of some sort, seeing as one can use different size units off one outdoor unit, then adaptor/reducer kits are provided to adapt different size pipework to the pipe connections on the outdoor unit.
I just installed a daikin 4 head multi and it came with a couple of these pieces that sort of look like a drier, that connects to the 5/8 pipe on the outdoor but then with certain other pieces could be used to reduce the pipe to 1/2 or 3/8 size.
27-09-2007, 12:21 PM #6
Buldging copper pipe ? It sounds a bit archaic , suction accumulators are like than on a capillary system but in A/C systems they usually have an accumulator in the outdoor unit . already fitted so they arent left out by accident .
When all else fails read the instructions.
27-09-2007, 09:05 PM #7
definately isnt a reduction kit, think some sort of baffler i will get pic next time i go the site, cheers guys
Suction gas <-> liquid line heat exchange and performance gains
By DaBit in forum Technical SpeculationsReplies: 30Last Post: 18-05-2010, 01:52 PM -
Suction line?
By SkyWalker in forum FundamentalsReplies: 6Last Post: 18-05-2009, 10:34 PM -
suction line freezeing
By karimihassan in forum Air ConditioningReplies: 4Last Post: 05-08-2007, 05:17 AM -
Minimal required R134a speed in suction line
By DaBit in forum CPU OverclockersReplies: 32Last Post: 08-05-2002, 05:19 AM
