Results 1 to 14 of 14
Thread: xarios 350 cab control
25-09-2007, 12:44 AM #1
i've just had to change a xarios micro and the customer wants the setable range on the cab control to be set to 4 i.e you can only set it to 4 degrees, i cant remember how to do this, can any body help? btw i dont mean when you press up down and defrost and change it from 0 -20 -29,
it can be done because they have 30 other vans that are locked at 4 degrees
25-09-2007, 09:47 PM #2
Re: xarios 350 cab control
try going into configs
25-09-2007, 09:51 PM #3
there is a carrier maintenance program that runs of a pc, if im not mistaken u can use this to change the param value.
ciao
26-09-2007, 10:26 PM #4
By configs do you mean push the pin in the back of the control where you select voltage and fan speed etc? its not in there?
this program? i have the latest vector/supra program but there is no serial port on the zarios?
where would i plug it in?
27-09-2007, 09:10 AM #5
pls provide your email add and i can send you the operating instructions for xarios 350 cab command. is your xarios 350 with road only or with standby?
27-09-2007, 10:01 PM #6
yes press the button on back of control scroll till u find SPOF= OFF SPON=ON if it doesnt appear software old
27-09-2007, 10:32 PM #7
its a brand new micro from glenside, do i have to be in a particular menu or mode when i press the button on the back? i get voltage, fan speed, drain heaters and 3et/2et etc, i dont get spon or off?
i have the xarios 350 os manual and it doesnt say it in there? if you want to mail be use cupid_stunt79@hotmail.com (i'm guessing i'm letting myself in for a whole load of spam now )
28-09-2007, 09:06 PM #8
what software is in micro press set and hold if no alarms fist reading is software revision
02-10-2007, 08:15 PM #9
your vector /supra program wont work on the xarios. the cab control harness plugs into a adaptor to upload software from what I remember for the xarios range
14-04-2009, 09:26 AM #10
hello, I have a Xarios 350 which is not switching ON, supply voltages are Ok. Does any can give me a hint what it might be wrong.
14-04-2009, 05:04 PM #11
Check ign. source from truck. I believe wire says "niem" and should be located in the vehicle fuse box.
14-04-2009, 08:52 PM #12
ignition feed is wire=ign it runs from truck supply fuse to pin4 of the miro thin wire test for broken wire
15-04-2009, 04:07 AM #13
I always wondered why they had "Niem" on that wire over here but maybe they don't anymore?
27-04-2009, 09:41 PM #14
microswitch fitted under condensor cover if cover is off unit is off
Airwell Florida Inverter Air Condition - in need of help
By AndY1 in forum Air ConditioningReplies: 21Last Post: 05-07-2008, 10:48 AM -
Frick Quantum LX Compressor control panel: Capacity Control Screen
By screw_geek in forum Industrial CompressorsReplies: 17Last Post: 15-06-2008, 06:47 AM -
Control scenario
By Mike Hopkins in forum Technical DiscussionsReplies: 5Last Post: 14-09-2007, 11:25 AM -
Searle cellar cooler control problem
By iceman007 in forum ElectricalReplies: 6Last Post: 06-07-2004, 08:57 PM -
New Capacity Control Solution
By embrown in forum New TechnologiesReplies: 19Last Post: 30-12-2003, 02:33 PM
