13-09-2007, 06:58 AM #1
one scroll compressor does not compress
hi friend.
we have a LG scroll aircondition compressor(model:SB061YAB).
we have not installed the compressor on A/C unit because here is one problem.
when we start the compressor (OUT OF UNIT) it dose not compress when we keep the discharge line closed with finger in result gas leake from discharge to suction.
what is the problem?
NOTE:
-THE COMPRESSOR IS THREE PHASE
-THE DIRECTION OF COMPRESSOR IS CORRECT.
-WE BOUGHT TWO NEW COMPRESSOR (LG- SB061YAB) both of them have problem .Last edited by karimihassan; 15-09-2007 at 04:27 AM.
13-09-2007, 10:57 AM #2
Re: one scroll compressor does not compress
Is this a single or three phase compressor? if it is three phase then it is probably running backwards.
13-09-2007, 02:35 PM #3
14-09-2007, 06:26 PM #4
Hi there,
Start the compressor and watch the condensing pressure. If it does not change then the rotation is wrong, change the phases.
If the condensing pressure goes up then it it correct.
Be careful, if scrolls run in wrong direction there will be a disaster.
CheersEven Einstein Asked Questions
15-09-2007, 06:03 AM #5
15-09-2007, 11:00 PM #6
What happens when the compressor is connected to the system as it should be?
15-09-2007, 11:14 PM #7
use of digital scroll technology
By katyalrk in forum Technical DiscussionsReplies: 6Last Post: 11-11-2008, 02:12 PM -
copeland ZR scroll vs VR scroll
By Lc_shi in forum Technical SpeculationsReplies: 7Last Post: 03-09-2008, 04:27 PM -
Scroll vs. Semi-Hermetic
By rickmor in forum CommercialReplies: 25Last Post: 18-06-2008, 05:26 PM -
Hermetic reciprocating versus hermetic scroll
By Cofreth in forum Technical DiscussionsReplies: 26Last Post: 19-11-2005, 06:29 PM -
Scroll Compressor
By dwallan in forum CommercialReplies: 1Last Post: 30-07-2001, 04:18 AM
