Thread: Maximum flex length
09-09-2007, 07:30 PM #1
Maximum flex length
What is the maximum length of cable flex you can have on portable appliances.
Regards Bernard
09-09-2007, 07:53 PM #2
Re: Maximum flex length
As far as i am aware its 2mtrs.
Grumpy men live longer
09-09-2007, 09:27 PM #3
What about mowers, vacuum cleaners? just a though, havn't a clue!
09-09-2007, 09:48 PM #4
I don't think anyone's come up with a law for that yet, but I can tall you what happens: the fuse blows!
Back in my youth I had to do some welding about sixty five yards from the plug in the wall. This was pre inverter welding kit. The fuse blew again and again. Silly billies that we were we put a split pin in place of the fuse.
It worked, but made a nasty mess of the fuse board
09-09-2007, 11:55 PM #5
The only thing that I know of is that extension leads should be clipped if longer than 2m which is why most shops only sell the short ones.
20-09-2007, 07:38 PM #6
Length isnt a issue as such what you have to remember is the longer the lead the more voltage you will drop and more current you will draw. Most ext. leads start at 15/25m using 1.5mm, we rented a mobile fridge unit to fords once to keep there free ice cream frozen the unit started playing up after one day went to see what the problem was and they had approx 400/500m of ext cables connected(british 16atype) using various 1.5 and 2.5mm. Chewed there for that idiots.
Split System max pipe run length?
By fridge doctor in forum Air ConditioningReplies: 4Last Post: 18-08-2007, 01:14 AM -
Equivalent length for fittings
By harsen in forum Technical SpeculationsReplies: 12Last Post: 11-04-2007, 05:13 AM -
extra length v pipe size v additional charge
By misterfixit in forum Air ConditioningReplies: 18Last Post: 03-01-2007, 07:57 PM -
Eqivelant Pipe Length
By frank in forum Air ConditioningReplies: 21Last Post: 26-03-2006, 12:20 AM -
Maximum Discharge Temperature
By dallan in forum CommercialReplies: 6Last Post: 13-09-2004, 07:42 AM
