Results 1 to 2 of 2
Thread: Toyota MR2 Assistance
29-08-2007, 07:46 PM #1
Due to a very heavyweight ICE install in its boot (front end) does anyone know where the A/C service points are on a mark 1 vehicle. Ruddy thing is wired up like a radio station.
I would normally go on a panels off hunt not usually playing with Japanese models but this beast would take hours to strip.
Suspicion is under the panel nearest the windscreen 'cause thats where the LP switch cable seems to go....
R12 to R134a day......
Going green is dumping a perfectly servicable compressor...?
Derek
30-08-2007, 04:35 PM #2
Re: Toyota MR2 Assistance
Not sure of the mark 1 but the mark 2 is spare wheel out, plastic shroud out and it is in the right hand corner closest to the windscreen and the liquid valve is a 3/16" fitting and the sucton valve is pretty close to the liquid and is 1/4".
toyota prius compressor spec.
By max2 in forum TransportReplies: 0Last Post: 11-08-2007, 09:00 PM
