Results 1 to 8 of 8
    Jul 2006
    Romania
    43
    99
    r134 is a drop of r 12?
    hy guys!
    i will like to know your opinion about this....here in romania we start do not use r 12 from 2 yrs,but the small compressor with which we work have inside mineral oil...it will work those compressor with r 134 if we don't replace the mineral oil with the poe oil?
    chers
    Jul 2007
    Australia
    1,845
    Re: r134 is a drop of r 12?
    r134a requires POE oil, it doesn't mix with mineral oil. There are blends though that work with mineral oil in r12 systems, like sp34e, plus some 40x refigerants.
    http://www.solpower.com.au/sp34e.html
    3,856
    For R12 replacement i would use R413A (Isceon R49)
    Jon
    Jul 2007
    Australia
    1,845
    That's the r4xx refrigerant I was trying to think of. Unless it comes under a FX name, I've never used it, though isceon rings a bell).
    In australia we pretty much stick to sp34e. Must be because its cheap and easy to get here, as it's just 97% r134a, with 3% propane to mix with the oil.
    Apr 2006
    41
    1,620
    To replace R-12 use 80% R-134a and 20% R-600a
    Jun 2007
    Cyprus
    73
    252
    [quote=paul_h;74930]That's the r4xx refrigerant I was trying to think of. Unless it comes under a FX name, quote]
    FX56 is the one you are thinking of... Du Pont I think.
    Jul 2007
    Australia
    1,845
    [quote=fridge doctor;75822]
    Yeah, I did heaps of retrofits in the mid 90s. There was a lot of large plant A/Cs at an air force base I worked at with r12 and r500 refrigerants. We had to change them to r134a, FX56 and FX57. Back then there wasn't much choice of drop in refrigerants.
    The R134a was a disaster, lots and lots of oil changes, and heaps of leaks suddenly appeared on 30 year old joins. Also the crank case seals on open drive compressors started to fail, so we tried fx56 and fx57 with better success.
    Feb 2005
    United Kingdom
    73
    The Drop in Replacement for R12 is R409A
  1. A question about the pressure drop in coil .
    By jackcn in forum Fundamentals
    Last Post: 13-12-2008, 05:10 PM
  2. pressure drop of pump return line ammonia
    By Moeller in forum Fundamentals
    Last Post: 04-09-2007, 05:21 AM
  3. Optimal pressure drop in condensers and evaporators
    By MrReds in forum Refrigerants
    Last Post: 06-10-2006, 10:12 PM
  4. Replies: 17
    Last Post: 25-08-2003, 09:56 PM
  5. TEV capacity related to pressure drop
    By DaBit in forum CPU Overclockers
    Last Post: 06-12-2002, 05:11 PM
