Thread: Electricity consumption porblem
23-07-2007, 05:43 PM #1
Hello. I want to know the power consumption of a small refrigerator. the specification sheet says the power output is 320 watts. I know that the power input depends on the efficiency of the motor and other components, but being conservative, is there a factor that would let me know it?
thanks
alberto
23-07-2007, 05:54 PM #2
Re: Electricity consumption porblem
Well, how long is a piece of string?
Seriously,
The compressor power consumption will roughly be 1/2 of the cooling duty.
But that wasn't your question now, was it?
The energy consumption has too many variables to estimate without all the design data.
Run times?
Defrost?
Efficiency?
No of starts and stops / given time?
And the list goes on.....
Sorry
23-07-2007, 07:22 PM #3
the efficiency of amost electrical divices lays around 0.8 so if you calculate it would be arround 400 watts
23-07-2007, 07:31 PM #4
Is this a college question or something nearer to home.
The use of an ammeter would establish exactly what the power being used is.
Also, the specification for the product should detail power input as well as output.Brian - Newton Abbot, Devon, UK
24-07-2007, 09:24 PM #5
Welkom Belgenman. Ik hoop dat je hier een beetje uwen draai zult vinden.
I think you misunderstood the question. If the power output on a domestic refrigerator states 400 W outputs (this is the refrigeration capacity expressed in Watt) then, you have to divide it wit +/- 2 to 2.5 to know the power input.
To measure it precise, follow the way Brian_UK described.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
Monitoring elect. consumption of VRV for each storey..
By MuhengineeR in forum Air ConditioningReplies: 9Last Post: 14-08-2008, 01:48 AM -
Very High Energy Consumption
By gdiaz in forum Trouble ShootingReplies: 12Last Post: 17-01-2007, 03:56 PM -
Daikin KRP2A61 Card Power consumption
By EddieC in forum Air ConditioningReplies: 5Last Post: 19-08-2006, 04:08 PM -
need energy consumption data
By gokhan in forum Technical DiscussionsReplies: 2Last Post: 25-05-2006, 12:48 AM -
Direct Energy Consumption Question
By v8dve in forum FundamentalsReplies: 1Last Post: 05-04-2003, 03:31 AM
