Results 1 to 2 of 2
Thread: IMI WM 60 Wall Mount R407c
23-07-2007, 03:29 PM #1
I dont know much about IMI units, normally they are pretty simple. The other day I was called to a unit that wouldn't run. There was no cooling signal to condensor. I found the pump, float etc faulty and replaced. The indoor fan runs fine, stat seems ok and all wiring seems spot on. Does anyone have any experience with these units or any ideas of what could cause this.
23-07-2007, 05:42 PM #2
Re: IMI WM 60 Wall Mount R407c
Have you tried a full reset of the system; power off and on again?
Don't know that particular unit but are you getting any fault codes from the indoor unit?
You say that the float and pump were faulty, what about the pump board? Are you getting a signal through the board?Brian - Newton Abbot, Devon, UK
Fresh Air Wall splits
By gwilliamson in forum Air ConditioningReplies: 0Last Post: 23-03-2007, 06:03 PM -
wall mount pumps
By refaircon in forum Air ConditioningReplies: 5Last Post: 23-03-2007, 11:21 AM -
Daikin 5kW wall mounts.
By Temprite in forum Air ConditioningReplies: 2Last Post: 20-10-2006, 12:17 PM -
R407 C wall mount LG 7 Kw
By Abe in forum Air ConditioningReplies: 54Last Post: 12-07-2004, 10:35 PM -
R22 vs R407C.....................again!!
By Abe in forum Air ConditioningReplies: 5Last Post: 24-07-2003, 12:21 AM
