Results 1 to 9 of 9
Thread: trane chiller flow
20-06-2007, 02:44 AM #1
trane chiller flow
i would like to determine flow of the water through the chiller. I know the pressures on the incoming and outgoing sides - can i determine flow from this pressure difference? and if so, how?
regularly get compressors locking out "low pressure control open" and "evap flow proving switch"
am told that there is a water flow problem causing this, and i would like to confirm or deny.Last edited by ff93; 20-06-2007 at 03:22 AM.
20-06-2007, 05:13 AM #2
Re: trane chiller flow
I think the only option, would be a flow meter.
20-06-2007, 05:18 AM #3
Hi there,
You can estimate the chiller water flow like this :
1- Measure water inlet and outlet temperatures. (ti , to)
2- Measure suction and discharge pressures and from the refrigerant pressure-temperature chart find the corresponding temperatures which are evaporating and condensing temperatures (te , tc).
3- Go to your compressor catalog and find the capacity at the operating conditions.
4- use this formula Qe= m x Cp X TD
Qe = compressor capacity (kW)
m = chiller water flow in (kg/s)
Cp = water heat capacity (4.18 kJ/kg.°K)
TD = ti - to
When you find the water mass flow rate in (kg/s) then you can convert it to volume flow rate (m³/s).
Volume flow rate = mass flow rate x density
Hope this helps.
CheersEven Einstein Asked Questions
20-06-2007, 09:12 AM #4
20-06-2007, 05:11 PM #5
Access to information can sometimes be difficult to determine, ie design data etc.
One easy way of determining water flow rate through a chiller would be to run it on full load and check the evap td, ie difference between inlet and outlet temps.
The design td for most chillers is around 6 deg, ie 12deg inlet temp, and 6deg outlet temp.
A td above 6deg = low flow rate, if its as low as it looks from your thread you should notice fairly quickly.
A td below 6deg = highher flow rate than design.
Also, chiller may be tripping on antifreeze if flow rate is low through the chiller.
Good luck!!!
21-06-2007, 12:47 AM #6
thanks for the answers!
I am not a techie, but I will try to find out / figure out according to your suggestions... i will let you know in the next day or two what I can find out.
incidently, the thing locked out today... again.
21-06-2007, 09:29 AM #7
Normally a valve would be installed in either inlet or outlet, where one can measure flow, for instance a TA valve or one of oventrop.
Check with the company who did the installation and have them measure the flow over the evaporator.
Also check and see if there's enough water/ brine in the installation and no air!
21-06-2007, 08:17 PM #8
Have you checked the water filter and anti freeze concentration i normally find a clean of the filter sorts out any flow probs
22-06-2007, 03:25 AM #9
Trane has published data on pressure drop vs gpm. You just need a model number for the chiller.
Trane & Carrier Chiller Data
By mustafa in forum Air ConditioningReplies: 8Last Post: 03-05-2009, 04:10 PM -
Trane Air Cooled Chiller
By iceman007 in forum Trouble ShootingReplies: 26Last Post: 11-04-2007, 08:30 PM -
Connecting Trane Water chiller to air handling unit
By celtictech in forum FundamentalsReplies: 10Last Post: 08-03-2007, 06:14 PM -
trane chiller
By ric in forum Air ConditioningReplies: 3Last Post: 14-09-2006, 08:03 PM -
flow through chiller design
By sucker_dave in forum Technical DiscussionsReplies: 43Last Post: 08-09-2006, 06:26 PM
