Thread: Tescos Temperature Flag
18-06-2007, 07:19 PM #1
Tesco use a small inch square sticker as a temperature indicater.If case is within its temp range then the square is solid black,if temperature rises then a fan begins to apear.Does any one know at which temp these flag are activated.
Regards Bernard
18-06-2007, 08:18 PM #2
18-06-2007, 09:15 PM #3
Re: Tescos Temperature Flag
Hi Chillin
The store are convinced that these flags should be solid black even when they stick them on the ticket edging.I think they should only be placed on the rear panel measuring the air of.
What was the name of the company ?
Regards Bernard
18-06-2007, 09:23 PM #4
I think they are set to start turning at 5c and complete at 8c.
That is for dairy and other foods like pies and pre-packed spams.
The fresh meat ones should be cooler and activate at
a lower temp.
Are they the ones with what looks like a fan blade on them when in high temp.
Cheers taz.
18-06-2007, 10:05 PM #5
http://www.t-m-c.com/index.html
Dock road,
Connahs Quay.
They had a few water chillers and A/C units, thats why I was there.
and go get a cuppa
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM -
re ref. circuit
By shsalameh in forum FundamentalsReplies: 5Last Post: 06-08-2007, 12:59 PM -
Q=? h1=? mechanical schematics
By fridg in forum Technical SpeculationsReplies: 22Last Post: 19-03-2006, 01:43 PM -
Article in ACH&R News
By Gary in forum FundamentalsReplies: 8Last Post: 20-05-2003, 12:27 AM -
TEV with MOP: how to keep valve body temp above bulb temp?
By DaBit in forum FundamentalsReplies: 5Last Post: 16-10-2002, 12:38 AM
