15-06-2007, 01:16 PM #1
Where from can I get compresssor to Multi deck chiller?
Hi i have bought used Verco Multi deck chiller, unfortunately the compressor is broken and the fuze go off every time I turn it on. Please give me any advise.
15-06-2007, 05:35 PM #2
Re: Where from can I get compresssor to Multi deck chiller?
Ceez
I would call a reputable Refrigeration company to diagnose the problem/s on site.
With Kind regards
MarkLast edited by Mark; 15-06-2007 at 05:42 PM.
15-06-2007, 11:02 PM #3
Stop turning it on, its not going to fix itself and you risking an electric shock if its got an earth fault.
16-06-2007, 06:08 PM #4
Every fridge engineer can fix this for you.
Apparently, you're not an experienced tech, so better leave if for the pro's.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
Dunham Bush Chiller Alarm
By Regulator in forum Air ConditioningReplies: 11Last Post: 08-12-2010, 01:42 AM -
DIY aquarium chiller
By BarraCuda in forum Technical DiscussionsReplies: 18Last Post: 06-10-2010, 11:02 PM -
York Screw Chiller How low will it go?????
By bruceboldy in forum Industrial CompressorsReplies: 11Last Post: 10-08-2007, 10:29 PM -
Water Chiller
By lana in forum Technical SpeculationsReplies: 20Last Post: 23-06-2007, 01:19 AM -
Connecting Trane Water chiller to air handling unit
By celtictech in forum FundamentalsReplies: 10Last Post: 08-03-2007, 06:14 PM
