Thread: Career chiller
07-06-2007, 09:47 AM #1
Career chiller
I'm working on this chiller it's winter now, so i need only heating i'v got 160 fan coils with electrical duct heaters .The problem is that many cold water stop valves are leaking so even on heating i'm geting cold air.My question is can i shut water valves cose i need only heating right now?Would that afect system?
07-06-2007, 01:18 PM #2
Re: Career chiller
The quick easy answer is yes close the valves.
The more complex answer would be if it is winter and only heating is on why is cold water passing through the valves?
Is the system still in use to chill other sections?
If it is then isolate the valves local to the coil and you should be fine.
If the system is not required just shut down the system and isolate a few key valves to prevent heat transfer through conduction.
Cheers taz
07-06-2007, 10:40 PM #3
Dunham Bush Chiller Alarm
By Regulator in forum Air ConditioningReplies: 11Last Post: 08-12-2010, 01:42 AM -
DIY aquarium chiller
By BarraCuda in forum Technical DiscussionsReplies: 18Last Post: 06-10-2010, 11:02 PM -
York Screw Chiller How low will it go?????
By bruceboldy in forum Industrial CompressorsReplies: 11Last Post: 10-08-2007, 10:29 PM -
Water Chiller
By lana in forum Technical SpeculationsReplies: 20Last Post: 23-06-2007, 01:19 AM -
Connecting Trane Water chiller to air handling unit
By celtictech in forum FundamentalsReplies: 10Last Post: 08-03-2007, 06:14 PM
