Results 1 to 8 of 8
    Sep 2005
    Singapore
    59
    145
    How to define system is sufficient charge for cars
    May I know how to check the system whether is sufficient charge for R-134a?
    System have no liquid sight glass.
    What is the usual delta T across evaporator coil and on what fan speed to check.
    To read suction and discharge pressure at what engine speed?
    System takes a long time to cool during the day when car was being parked under the sun.
    But can cool well after sunset or on raining day.
    Thank you.
    Jan 2006
    Valrico, Florida
    509
    Re: How to define system is sufficient charge for cars
    Quote Originally Posted by jollycold View Post
    R.T.F.M is the only true way
    I had to google to see what he was talking about
    I cant stop laughing now
    Aug 2005
    uk
    45
    the simple way is just touch the suction pipe,if it is cold you are nearly in the correct charge of gas.and if you have thermometer what i remember max. is 13 degrees C.check the air temp.in vent near to window.if it is below 13 c your cooling issatisfactory.
    Jan 2003
    Crewe, United Kingdom
    58
    723
    22
    With the advent of variable displacement compressors, the only way to check the charge is to recover and weigh what was in there. the correct charge weight may be on a sticker under the bonnet
    The vent temperature varies widely from one model to another depending on the airflow of the vents, some cars rely on a high air flow and higher vent temps, others have a lesser air flow and have a lower vent temp, the manufacturer should have the required data for the delta T for a range of ambients and RH
    Don't forget that in the summer, the interior of the car stores a huge quantity of heat and so will take longer to cool down than it would in the evening
    Generally I tend to check the centre vent temperature with the fan on full, recirculate on and the engine at 1500rpm
    Karl
    Aug 2001
    1,046
    Absolutely.
    RTFM, then if it still doesn't work, do what its says!
    Dec 2004
    Mexico
    86
    58
    Years ago, I had a device called an electronic sight glass, which clamped onto the liquid line at two points and beeped when a bubble went by. If there is still such a device, it might be able to be used to find the fully charged point. My electronic sight glass was made by Snap-on Tools.
    May 2006
    china
    98
    Quote Originally Posted by nh3wizard View Post
    UTFG is also the good way for u..
    Feb 2001
    Doncaster, England
    199
    There are CDs available called AUTODATA.
    They are a bit expensive if you have to buy them, but if you go to computer fairs it is amazing what is available.
    They tell you where all the components are in the car, how much refrigerant etc.
    Tony
  1. Daikin fault codes
    By Chris2005 in forum Air Conditioning
    Last Post: 21-03-2012, 10:09 PM
  2. System Burn Out Troubleshooting
    By altaf22m in forum Technical Discussions
    Last Post: 07-05-2010, 09:24 AM
  3. Replies: 19
    Last Post: 15-04-2008, 07:03 PM
  4. Total System Charge
    By dallan in forum Fundamentals
    Last Post: 27-12-2004, 08:18 PM
  5. Refrigeration system proposal; comments please.
    Last Post: 01-01-2003, 03:42 PM
