Thread: draft beer dispensing equipment
28-05-2007, 06:47 PM #1
HI GUYS INEED YOUR ADVICE AND HELP???????
I WAS OFERED TO INSTAL DRAFT BEER DISPENSING EQUIPMENT, AND TO MAINTANCE THEM.
DOES ANY BODY HAS ANY EXPERIENCE TO FILLME IN HOW TO DO IT/
MOST OF MY EXPERIENCE IS REFRIGERATION. AND AIR CONDITIONING..
THANKS YOU AND I WILL BE WAITING FOUR YOUR REPLY.....:
29-05-2007, 01:10 AM #2
Re: draft beer dispensing equipment
You need to be more specific.
Are you refering to the beer chillers or are you talking about the beer dispenceing side?
In southern Europe I spose it would be gas dispense.
You connect the dispenser (on the bar) to the barrel connector.. If its chilled the pipe goes through the chiller then to the bar.
In most Eupopean countries I've been to the barrel is in close proximity to the bar.
If you are talking about the chillers then they are nothing special. They are just small self contained water chillers. Some even pump water through the pipeing loom to keep the beer cool.
I would need more info to be of more help.
Cheers taz.Last edited by taz24; 29-05-2007 at 01:14 AM.
29-05-2007, 02:28 AM #3
I concur with Taz24: but adding CO2 pressurization and pressure reduction. Check the job description.
Also, in Spain, servicing - due to food safety - has incorporated digital dating/checking of pipe cleaning (dis-infection) and servicing... this is by observation, I deliberately avoided lugging small but heavy water filled coolers (ice block cooling accumulation) up steps, down steps + 100m sprint before the local cops spot a badly parked van + negociation of the dispenser (pipes, cooler placement, power points etc.) into a badly designed bar (degree qualified engineers again!!!)
Some more advanced venues have a cool room for the kegs, but usually the storage rooms even lack a fan to renew the air where the beer cooler are , so much for common sense ecology//energy/money saving - as for the beer that comes from such rooms: yuck !
P.S. Since beer (of whatever quality) will always be sold in tourist areas, if the pay keeps you afloat go for it, the problems will usually be covered by experience, you will have some spares and the perks on site could be good (barmaids, free on the house etc .)
30-05-2007, 09:39 PM #4
Beer
By frank in forum HobbiesReplies: 29Last Post: 13-09-2009, 05:23 PM -
Draft beer dispenser
By botrous in forum Technical DiscussionsReplies: 14Last Post: 23-01-2006, 10:54 PM -
Draft Beer System Help
By PAXFREON in forum Legal-Business-MarketingReplies: 26Last Post: 17-12-2004, 10:41 PM -
My Customer's Air Conditioner isn't keeping the beer cold!
By herefishy in forum FundamentalsReplies: 30Last Post: 26-06-2002, 02:49 PM -
I dream of Beer in my case...
By BlueMania in forum Technical SpeculationsReplies: 9Last Post: 12-02-2002, 07:56 AM
