26-05-2007, 02:11 AM #1
Meat display cases medium temp! R-22 Defrost settingS?
I need to know from anyone that can help? what should i set these three medium temp closed meat display cases for on time setting for defrost, its a regular paragon 8140 b type, for typical conventional defrost,,,
These cases are gravity fed, not forced air!
the other thing is, is theres a low pressure control to the compressor on the service factor tubing of a reciprocator, towards the top of the can type compressor, where the factory charges or checks the unit for pressure losses, etc; thats where some guy installed the compressor control , and i believe that its a problem to hook it up there it only short cycles the compressor during the off cycle, maybe its the valves leaking by, or its a solonid valve leaking, or finally its just not the right place to insatll a low pressure control to bring on the compressor!
am I right about this being a not a right place to install it?
this is a two question post!
I just have to get off my but after defrosting these and go and do the foot work , i guess!
I did find the defrost set at one time a day for 90 minutes! that didnt do the job!Last edited by isitfixedyet; 26-05-2007 at 06:47 AM. Reason: type-o's lol
26-05-2007, 07:58 PM #2
Re: Meat display cases medium temp! R-22 Defrost settingS?
Q2, you can fit a pressure switch anywhere. Try adjusting the diff.
and go get a cuppa
27-05-2007, 02:15 AM #3
isitfixedyet, you win the prize for the most rambling question from the USA. Let's hope that you win out over the UK, once Refrigeration Idol is invented. But seriously
I need to know from anyone that can help? what should i set these three medium temp closed meat display cases for on time setting for Defrost, its a regular paragon 8140 b type, for typical conventional defrost,,,
the other thing is, is theres a low pressure Control to the Compressor on the service factor tubing of a reciprocator, towards the top of the can type Compressor, where the factory charges or checks the unit for pressure losses,
A two hour defrost once a day should be all you need. If you have your gauges on and the suction pressure fails to rise above the Saturated suction pressure of ice melting you likely have a leaking solenoid valve. This might also explain some of your other observations.
finding a leak in 11 display cases all conected
By tsounos in forum Supermarket RefrigerationReplies: 52Last Post: 08-05-2007, 06:19 PM -
display case temp alarms
By shark26 in forum Supermarket RefrigerationReplies: 9Last Post: 17-01-2006, 10:07 AM -
George Barker Display Cases
By Mark in forum Supermarket RefrigerationReplies: 9Last Post: 02-09-2004, 10:43 PM -
Multiplex For Low Temp and Medium Temp
By allanbaker in forum Technical DiscussionsReplies: 0Last Post: 28-11-2002, 10:15 AM
