Thread: remove
01-05-2007, 09:35 PM #1
remove
hi guys i have purchased a panel van with a refrigeration unit on the roof. is it easy to remove ? if so how ?
thanks
steve
01-05-2007, 10:55 PM #2
Re: remove
Hi Steve and welcome to the forum.
The first thing that you MUST do to comply with the law is to check the system degassed. This may require the services of a vehicle air conditioning technician. Check your local Yellow Pages.
After that the removal should be reasonably straightforward.
I will repeat, do not proceed without having had the refrigerant removed; apart from the legal side you could injure yourself by the uncontrolled release of the gas. In liquid form especially it will cause severe frostbight, you lose finger tips etc.
The roof mounted unit is probably just the condenser coil and cooling fans. Remove any covers and you should see some hoses connected to the coil with a screwed connector ( a bit like a plumbing joint, only better ), undo those and remove the remaining bits and pieces.
Inside the truck you will find the evaporator with similar pipe connections, release those and you're almost there.
Now, in the engine compartment you will find a compressor that is driven via a belt from the engine and assorted bits of pipework.
Use a atch tray of some sort because when you undo the connectors on the compressor you will probably have some oil to drain out.
You should then be able to remove all the bits of tube and hose and cable that are remaining which just leaves all the holes to fill in .
Have fun with it Steve and seriously, take care - injury is not worth the effortBrian - Newton Abbot, Devon, UK
02-05-2007, 06:02 PM #3
Re: remove
Hi steveb,
I suggest that you do exactly as Brian said otherwise you will hurt yourself or the others.
Apart from that you can be fined a lot if you let the refrigerant into the atmosphere.
Good luck
CheersEven Einstein Asked Questions
02-05-2007, 10:30 PM #4
Re: remove
Drive your car under a bridge which isn't high enough
02-05-2007, 10:47 PM #5
how do you remove the evaporator cover on the samsung rs21 range
By bazigaar420 in forum Trouble ShootingReplies: 8Last Post: 20-08-2010, 11:33 PM -
Maisotsenko cycle
By Lc_shi in forum New TechnologiesReplies: 11Last Post: 17-07-2008, 01:35 PM -
Bock AM5 compressor's shaft seal failiure
By Gareth in forum Trouble ShootingReplies: 11Last Post: 05-04-2004, 09:12 PM -
Article in ACH&R News
By Gary in forum FundamentalsReplies: 8Last Post: 20-05-2003, 12:27 AM
