Thread: r12-r413a conversion
24-04-2007, 10:08 PM #1
I am working on a 1991 nissan skyline r32 gtr air-conditioning system and has no refrigeration plate. I know it is r12 and been told (from another post)use r413a. Does anyone know how much to weigh in or what sort of pressures and temps i am looking for?
Also does anyone know the refrigeration charge for a nissan skyline r33 gtr. I know it is r134a.
Do all jap imports have no refrigeration plates?
24-04-2007, 10:42 PM #2
Re: r12-r413a conversion
Robin, have a look here at Dupont site where you will find all the details on R413a
24-04-2007, 10:50 PM #3
I don't really work on aircon's car but if you're sure of the new refrigerant follow that:
1/ find on the web the compressor. Help yourself with the nameplate
2/ check if the compressor oil has to be changed from mineral to POE.
3/ check once again what kind of refrigerant the compressor could admit (possible r134a when changing oil )
4/ after vaccuming put first 0.3 to 0.5 kg max
5/ after don't care about pressure but work with temperature, it's better in this case ( of course you need the curve of you refrigerant )
6/ at last try to work as well on LP but slighty lower than an usual airconditionner i.e from -7 to 0°c max when you tend to the maximum fresh air.
It's not my area but i hope this will help
cool#9
25-04-2007, 05:32 PM #4
25-04-2007, 07:23 PM #5
make nissan
type skyline
model r32 gtr
refrigerant r12
charge ?????
26-04-2007, 09:47 AM #6
26-04-2007, 09:16 PM #7
Thanks for all your help.
