14-06-2002, 10:18 PM #1
Can anyone help me w this compressor!?
Hey guys,
Ive got a compressor from a fridge and I need to know what spec it have.
In the label says R12 152w, does this means that this compressor is a 152w at -20c?
And, since R12 is now ilegal, can I use r134 for the compressor?
16-06-2002, 04:23 AM #2
THe 152W may be the manufactures code., OR how many watts it can consume. But SInce r-12 is no longer produced. You are doing to have to find a good drop in. R-134a will not work unless you have the new oils in it.
Preston Roy Powell
www.thinkcool.net
15-03-2003, 12:07 AM #3
Depending on what your going to use that compressor for changes the refridgerant that you should use.
If you need this for something low temperature, i am going to recommend propane (not stuff from the BB-Q, but pure propane)one mans trash is another mans treasure
17-03-2003, 02:09 PM #4
The compressor was manufactured by Unidad in Spain. The 152w
is probably the compressor power Is there a number like AE1336A or L45AU on it? This would be the model number of the compressor.Len Fiddler
can overfilling/overcharging damage a compressor?
By fredjchavez in forum Trouble ShootingReplies: 10Last Post: 12-02-2009, 10:30 AM -
Compressor pumping efficiency
By shogun7 in forum FundamentalsReplies: 0Last Post: 25-02-2004, 10:50 PM -
One Half of a Part Wound Compressor Motor is Burnt
By aygul in forum Trouble ShootingReplies: 2Last Post: 25-08-2003, 11:11 AM -
Compressor failure...... cause
By herefishy in forum Technical SpeculationsReplies: 8Last Post: 06-12-2002, 12:15 AM -
Starting a compressor, and receiver questions.
By DaBit in forum Technical SpeculationsReplies: 9Last Post: 24-08-2002, 12:37 PM
