Results 1 to 2 of 2
    Mar 2007
    Netherlands
    55
    15
    Mitsubishi Hyper 2,5 Kw
    Hi a/c egineers
    I had a question from a costumer for a satteleit unit with a cappacity of of 2 Kw - air flow 500M3/h static presure 25 Pa- COP4 and a inpout 400 Watt
    I looked but there is no standaard unit on the market
    Now I toke the outdoor unit of a mitsubishi Hyper unit and build the printing board from the inside unit in our new sateleit indoor unit and make a test unit.
    Now the following is happend.
    When i don not use the standaard indoor motor,the print is giving a failer. I use a other evap fand (220 Volts) because i need a static pressure of 25 Pa.
    What can i do with the print so that it worked with out the standaard fan.
    Now i put the standaard fan in the unit so it can work.
    When the unit is running on 7.5 Bars (R-410a) mine inpout is 1100 Watts thats much to high my COP is to low.
    When i lower the suction to 4 bars my inpout is 375 Watts and my unit give a capicity of about 1800 watts thats ok.
    can somebody tell me what i'm doing wrong and can help with this unit.
    When the unit is working properly i can sell about 300 units each year to resorts all over the world
    i hope somebody can give some answers
    jan willem
    PS i hope you can read my bad englisch
    Jan 2007
    SPAIN
    172
    Re: Mitsubishi Hyper 2,5 Kw
    Jan:
    Are you trying to modify Mitsubishi A/C units, if switche/inverter, which model(s)?,?,?
    Are you cooling electronics?
    Please answer and we can study your difficult English again...
