Thread: Hello Friends
    Mar 2007
    London, UK
    36
    Hello Friends
    Hi there, my name's Sid.
    I have just joined so hopefully you will all be hearing more from me.
    Sep 2005
    Singapore
    59
    145
    Re: Hello Friends
    Hi Sid,
    Welcome to RE & enjoy yourself here.
    *cheers*
    Aug 2005
    5,302
    Re: Hello Friends
    Greetings Sid.
    Welcome from the US.
    US Iceman
    Oct 2003
    5,630
    34
    Re: Hello Friends
    Greetings Sid,
    Hello,
    A warm welcome from Belgium.
    Don’t hesitate to ask any question and share your knowledge and experience with us.
    This forum is read worldwide and you may expect a professional answer.
    If you post a question with the units you’re used to work with, place between brackets the other units. So if you normally work with SI units (bar, °C, m³/h..), place then between these units the proper IP units.
    You can do the conversion with a free software program Uconeer
    You can find it on http://www.katmarsoftware.com/uconeer.htm#download
    Or you can use the spreadsheet of Dan posted on http://www.refrigeration-engineer.co...0617#post50617 post 6.
    When you have a technical problem, try to post as many as possible readings you have made. You will see that we need many times condensing and evaporating pressure; discharge, suction, evaporator outlet and condenser outlet temperatures. Try to measure these very accurate.
    The better you measure these, the better we can help you.
    Note also band names, types of all the items installed in the installation.
    I hope that you stay a long time with us and that you can contribute to expand this forum.
    Peter
    11,024
    Re: Hello Friends
    Welcome Sid, sit back, relax, enjoy and get typing
