17-02-2007, 03:59 PM #1
Split Type AC that can run on 60 Hz
Hello everybody,
Does anybody know a split type AC unit that can run on both 1 X 230 V, 60 Hz and 1 X220 V, 50Hz?
19-02-2007, 07:23 AM #2
Re: Split Type AC that can run on 60 Hz
Thanks for the info. I also have found Daikin.
20-02-2007, 12:38 AM #3
Normally it would be 230v/50Hz and 220v/60Hz.
The '220v' 60Hz is obtained from across the 2 phases of an 'american' 3 phase supply. Dont forget to fuse both poles and use double pole isolation.
