Thread: Tk 486 Tier 1 Engine
07-02-2007, 11:12 PM #1
fuel issues,does anyone no a part # for a fuel supply update kit for the tier 1 engines, i'm trying to change the banjo fitting to 5/8 synflex and the part # that in my tt manual is not avalible i heard there was a kit now i have a customer that has about 300 210s and i am having some fuel issues with a few sometimes it a week or 2 between issues but i want to start changing the supply line from the filter head to the inj. pump
thanks any input app.
09-02-2007, 01:25 AM #2
Re: Tk 486 Tier 1 Engine
never mind i just got a service bulletin today and they have the kits in production now avalible in a couple weeks
12-02-2007, 05:50 PM #3
what kind of fuel issues are you having? Is it losing prime?
13-02-2007, 03:50 AM #4
I know that i have a lot of problems with tk yanmars (in line injection pump) not starting in the cold. The fuel solenoid doesnt pull to full fuel position and sputters on and may start or crap out. Is there a solution for this yet, or am i just the only sucker out there??
Reefermadness
16-02-2007, 08:45 AM #5
Reefermadness, I haven't really experienced that problem yet. Usually if I have one with fuel issues, the problem is the following:
Inlet screen plugged
filter plugged
lines not tight (sucking air)
old POS rubber washers on transfer pump (sucking air)
Vent on tank bad
bad return line check valve (fuel bleeding back to tank)
bad transfer pump check valves (fuel bleeding back to tank)
fuel solenoid
junk in the bottom of tank
water in fuel
fuel gelling up (especially the new low sulfur fuel)Last edited by fordrules; 16-02-2007 at 08:49 AM.
