Thread: flare nut spanners
30-01-2007, 09:19 PM #1
flare nut spanners
full/part set where does them?
looking for 3/8,1/2,5/8,1/4
thanx rob
30-01-2007, 09:38 PM #2
Re: flare nut spanners
Try FACOM from any good tool shop. I think many new flare nuts are metric externaly now but not sure.
Cheers Jon
30-01-2007, 09:46 PM #3
Dont forget that they will be sized AF "Across Flats"....the sizes you are mentioning are presumably pipe sizes.
3/4",7/8", 1", 1 1/8" are sizes that spring to mind without looking.
31-01-2007, 07:51 AM #4
I have still got a full set of King Dick spanners I had has an apprentice in 1978, no use these days as all flare nuts are metric.
Last edited by Brian_UK; 31-01-2007 at 11:00 PM. Reason: Enabled full tool name if you'll pardon the pun.
31-01-2007, 09:53 PM #5
Andy W
who did you work for back in 1978? were you in Stoke then?
Ian
