Results 1 to 12 of 12
29-01-2007, 08:19 PM #1
Capacitor Values for rotary compressor?
Hi I got a Matsushi-ta 2K-17-C3-R12-6A Rotary but it had no electrical and I can't find a PDF with the pin out and the value for the run cap. It is a PSC type unit that much I've been able to find out.
Is there any formula for calculating the correct size? but then again I have no power specs either
Any help greatly appreciated.
Thanks.
30-01-2007, 12:02 AM #2
Re: Capacitor Values for rotary compressor?
Found a bit on it but not the pin-out or cap yet..
http://www.panasonic.com/industrial/...d_benefits.pdfBrian - Newton Abbot, Devon, UK
30-01-2007, 07:07 AM #3
30-01-2007, 09:35 AM #4
Peachy. Well I think I found the pin outs finaly. I still hear the damned beeping in my ears 5 houres later <_<
30-01-2007, 09:37 AM #5
31-01-2007, 12:31 AM #6
Digging out college notes found a formula (Warning NO responsibility/liability accepted:):
Permanent condenser Split phase motor:
Note 1: "When running the Condenser should absorb 1Kva per Kw of motor power"
Note 2: low starting torque
C=(P*10^6)/(w*(V*V)) where C is uF; V=mains line voltage; P=motor power in watts (from horsepower conversion); w=2*(22/7)*Hz (Hz cycles of your mains)
Leaves one with the problem of what power is the motor, where did you get it from ? Any data there, otherwise the challenge will be work out HP based on cc/rev and rpm... any other formulas out there?
Dedicated to Santi for his near unreadable photocopies!!Last edited by momo; 31-01-2007 at 12:34 AM. Reason: missed out 10^6
31-01-2007, 05:06 AM #7
Awsome thanks. Now just need to find out its power draw in either amps or watts or horse power!
24-07-2008, 04:59 PM #8
24-07-2008, 05:15 PM #9
24-07-2008, 05:41 PM #10
Hi Pony,
If you know the HP or capacity in BTU and its AC compressor, I will give you a list of capacitors per compressor.
26-07-2008, 11:33 AM #11
05-08-2008, 11:13 AM #12
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
