    Nov 2007
    Australia
    64
    44
    North Star Ice maker
    Does anyone have any experience with working on these North Star icemakers?
    Jul 2006
    870
    27
    Re: North Star Ice maker
    Yes. What is the issue.
    Nov 2007
    Australia
    64
    44
    Can you remove the top gear hub without removing the drive key. The key just does not want to come out.
    I need to change the top bearing on a model 40 icemaker
    Jul 2006
    870
    27
    You do not have to remove the key to pull the gear. Just use a Hydraulic Jack and a chain. Use two studs screwed into the gear with a chain welded to the top so you get a straight pull. You need to install a jacking screw in the bottom of the machine first. After the gear is off you will need to make a wrench to unscrew the bearing retainer if you do not have one. The directions are in the Manual. Be sure the new bearing is a snug fit on the shaft. Otherwise you need to weld it up and re-machine it. Do you have the Manual? If not Northstar might send you a copy.
    Nov 2007
    Australia
    64
    44
    That sounds perfect. Thank you for that. That was my thought exactly.
    I have manuals from Northstar already.
    I tried getting some input from them regarding my situation and I just keep getting responses from their spare parts division... Their support is totally ridiculous.
    From their sales manager, he responded with
    "Outside of using a penetrating oil, there isn’t much that can be done to save the key.In instances like this, your best course of action is to carefully drill out the key using a 3/8” drill bit, and chipping out the pieces that remain.
    He followed up with.. " Do you need us to supply a new key ?
    What a joke...
    Jul 2006
    870
    27
    I was lucky. I worked for a Company that had a long history with them and even had a few drinks with the Chief Engineer.
    One thing to remember when using the large wrench. Put a SOLID bar through the wrench. And put a piece of pipe over that to pull tension on it. Then smack the bar with a sledge hammer.
    The older machines had a left hand thread. They converted to right hand a long time ago.
    Brings back memories-been almost 20 years since I worked on one.
    Let me know how it goes.
    Nov 2007
    Australia
    64
    44
    Hey... You want to come to Ozz and give me a hand ?? :-) ...
    Jul 2006
    870
    27
    Been retired too long. Content to live on my past Glories. (and forget the not so glorious flub-ups)
