    May 2020
    United Kingdom
    3
    Scania Higer 2018
    Hello all
    Can anyone point me in the right direction for fault code E41, (Compressor feedback, low pressure side)
    plenty pressure there but no power going to the LP switch
    Feb 2011
    scotland
    469
    Re: Scania Higer 2018
    Could you apply the correct voltage to the LP switch to test the switch and controls work correctly?
    Then trace back the wiring from the switch to find where your loosing voltage?
    May 2020
    United Kingdom
    3
    Yes thats a good start, I had 2 coaches this week with the same fault was kind of hoping someone could put there finger on the pulse with the issue as its very time consuming especially without the wiring diagrams
