Results 1 to 8 of 8
    Stevieg's Avatar
    Stevieg Guest
    Hotpoint Mistral FF93 doing my head in!!!
    Hi, new member here,can you please put me out of my misery.
    Problems with frost free fridge/freezer-freezer cold -22 but fridge warm no circulated cold air from freezer.The evap fan is running but cannot feel any air flow from vent in fridge (i have removed the damper)I have already replaced the evap thermistor (yellow) by suggestion from local domestic repair shop-i don't think they quite understood.I have checked both ducts that run to the fridge compartment and they are both clear.Surely if the fan is running i should feel the airflow unless the fan blades have moved out of position and not directing it properly-even so the ducts are quite away from the fan in the first place.The evaporator coils were quite frosty as well when i changed the thermistor.Any suggestions???
    Oct 2006
    Norwich Norfolk
    8
    Re: Hotpoint Mistral FF93 doing my head in!!!
    Only problem we have ever seen with these fridge /freezers is the thermisters, change the yellow and green ones, defrost the evaporator completely and ensure the drain hole has no ice in and that it is clear of debris. Should be fine after that.
    q0j0p's Avatar
    q0j0p Guest
    Exactly the same problem as mine, can you tell me what the yellow and green thermisters look like and where I will find them. Thanks
    Apr 2007
    London
    12
    Hi Stevieg,
    Have tested the defrost heater and also have you tested the defrost timer normally at back of fridge next to compressor,
    Thanks Fridge-Man
    Jayos's Avatar
    Jayos Guest
    I've got one doin my head in too.
    I have changed the evap thermistor and everything working fine for a couple of days.
    Checked today and the fridge is above temp again.
    Any ideas?
    How does the defrost work on these fridges? is it programmed on the pcb
    Jayos's Avatar
    Jayos Guest
    Can you help
    Anybody?
    Oct 2004
    Scotland
    1,454
    21
    The Evaporator coils were quite frosty as well when i changed the thermistor.Any suggestions???
    Did you not defrost it?
    You don't say that you did, so go back and defrost it and then make sure all the panels are on properly.
    Switch it back on and it should work.
    Chillin
    and go get a cuppa
    Oct 2004
    Scotland
    1,454
    21
    How does the Defrost work on these fridges? is it programmed on the pcb
    Yes.
    Any ideas?
    Sounds like the fan is cutting out for some reason.
    Did you make sure the new evap probe was secured tightly to the coil?
    Chillin
    and go get a cuppa
