Results 1 to 9 of 9
Thread: Earth Loop
12-12-2006, 06:16 PM #1
Earth Loop
What would be the minimum qualification required legally to carry out earth loop impedence testing in a commercial property.
Regards Bernard
12-12-2006, 07:01 PM #2
Re: Earth Loop
Sombody with the 16th edition?
taz
12-12-2006, 07:06 PM #3
Re: Earth Loop
I have 16th edition trying to find out if I also need 2391 inspection and testing?
Regards Bernard
12-12-2006, 07:20 PM #4
12-12-2006, 08:50 PM #5
Re: Earth Loop
No pa test certificate does not qualify you.
cheers bernard
13-12-2006, 05:59 PM #6
Re: Earth Loop
Hi Bernard,
I would have thought that if you've got 16th quallifications, then you should be competent enough to use a Loop Impedance/PSC meter. Presume you want to test the earth impedance for a new installed circuit, for the paperwork, or just check the integrity of the earth.
You do a reading at the distribution incomer and then another at you equipment connection point.
I use a 'Robin' unit that doesn't cause MCBs to trip.
Regards Adrian
13-12-2006, 08:14 PM #7
Re: Earth Loop
No its not a new installation,we carry out earth loop impedance tests yearly for a customer.
I was curious as we have peole with different quals as to what is the minimum qual required.I contacted the colledge today and asked there advise.They advised that a compotent person was qualified however it depends on what the customers insurers have stated as the minimum requirements.
I,ve also booked myself in for a 2391 course inspecting and testing.
Regards Bernard
04-01-2007, 11:35 PM #8
Re: Earth Loop
Do you have any other Electric Quals besides 16th Edition? (17th Edition comes out later this year)
17-01-2007, 02:52 PM #9
Re: Earth Loop
Hi Somebody,
Pls send to me also
