Thread: sanyo fault codes
19-10-2006, 09:00 PM #1
sanyo fault codes
Anyone have any info on sanyo fault codes?
Any info appreciated,
thanks in advance
Jase
20-10-2006, 10:11 AM #2
Re: sanyo fault codes
Hi Jase,
What type of Sanyo system? I've installed some Sanyo Multi Inverter systems (SAP-CMRV3143GJH is the outdoor unit) and so have some info on these....if I can help. Have you tried contacting Sanyo directly...I've found them to be very helpful in the past.
Adrian.
22-10-2006, 07:44 PM #3
Not sure as to which model of unit the sanyo is; One of the lads came up against it and I thought I would put the word out. I know it is a split on R410A.
Any phone numbers would be appreciated,
regards
Jase
22-10-2006, 09:22 PM #4
Cant post links yet but try: www sanyoaircon co uk
just add the dots!
Sanyo 0845 6126364
I use ESS... www essaircon com
they have a Glasgow office 0845 880 5864
theres also McQuay with a glasgow office 0141 427 9222
Cheers Adrian
22-10-2006, 10:05 PM #5
Hello I am Jerzy from Poland
22-10-2006, 10:25 PM #6
welcome Jerzy
24-10-2006, 07:34 PM #7
Thanks for the info Electro!
Jase
