Results 1 to 16 of 16
    Sep 2006
    washington
    Cold freezer / Warm fridge ?
    Hello everyone.
    I am having a problem with my Candy Iceline FF46/36FF fridge freezer.
    Problems:
    1) the compressor is switching on/off as normal ( i think )
    2) the freezer is -7C but the fridge is +15C
    the fridge temp sensor reads 5.72K ohms.
    Oct 2004
    Scotland
    1,454
    21
    Re: Cold freezer / Warm fridge ?
    The freezer compartment might be iced up. Switch it off for 24hrs and then try again. If it now starts working the problem is with the defrost system.
    Is this the one with the circuit board at the back? or is it in the top ?
    Chillin
    and go get a cuppa
    Sep 2006
    washington
    CU29321 PCB is on the front of the unit at the top.
    Auto Defrost comes on and off and the heater seems to be working.
    heater wires have a resistance of 338K ohms
    Sep 2006
    washington
    Found a solution !
    Sep 2006
    washington
    it involves a 12 volt fan and a hole.
    Sep 2006
    washington
    i would post a picture but i need 15 posts to do so.
    Sep 2006
    washington
    only another 2 posts left.
    Sep 2006
    washington
    one...... woohoo.
    Sep 2006
    washington
    Pretty extreme way of fixing the problem, but hey!
    I phoned around, and i can collect an 'almost new' fridge/freezer when my mate moves out of his flat.
    this is just a temp solution until then.
    I am going to cut the hole to the size of the fan, and the fan will be temperature controlled.
    Oct 2004
    Scotland
    1,454
    21
    Just upload the picture to ....
    http://www.tinypic.com/
    And then post the link here.
    Chillin
    and go get a cuppa
    Sep 2006
    washington
    Quote Originally Posted by chillin out View Post
    Chillin
    the problem is that this site doesnt allow url or images before you have posted 15 replies.
    A little post whoring solves that.
    Feb 2005
    Jamaica
    121
    Smithy,
    Dont know alot about the model u spoke about but that hole that you speak about should already be there some are controlled but a stat that just open or closes a flap.Check first if your getting air flow from that already excisting hole no sense tossing out a good fridge if it aint bad
    Sep 2006
    washington
    No holes in the fridge compartment (other than the one i made )
    Turns out that the fan is running almost continuously to get the temperature inside the fridge low enough, therefore i have simply left the fan on all of the time.
    3,856
    Needs another hole so the air can circulate
    Top bodging
    Jon
    Sep 2005
    uk
    499
    21
    Yes top bodging, and i do hope you enjoy your milk lolipops.
    Takes a licking, keeps on ticking.
    Mar 2006
    Norfolk
    160
    The title should be Warm freezer and warm fridge.
    Freezer should be at least -18C
    Paula
