Results 1 to 20 of 20
    Apr 2001
    2,099
    27
    New Carell Control Panel
    I put in the new design Master Cella Carell Electronic Control panel today,
    Yes, it looks cool and its sauve.........gone into a spanking new Cellrtherm cold room
    It has a built in isolator switch as well
    Question I have is...........The manual is terrible. The writing is small..........has anyone understood how to program the parametres, how to access the parameters.
    Im switching on tomorrow. I connected the cold room to the auxiliary relay no 2, as it says in manual.
    When i press the light switch , nothing happens.
    When I press the standby switch.........nothing happens.....!!
    grrrrrrrrrrrrrrrrr
    If some member has recently used this controller, pse help.
    I bought it from Hawco...........
    11,024
    Re: New Carell Control Panel
    Download the manual from here...
    http://www.carel.com/carelcom/web/en...=5&id_gamma=15
    Text is readable on screen (zoomed)
    File is 1.16mb
    Apr 2001
    2,099
    27
    Thanks Brian
    Printed it out.
    Still feel its been written in Greek
    11,024
    Quote Originally Posted by Abe
    Aren't they all ?
    No offence to the Greeks by the way
    Oct 2003
    5,630
    34
    Only now seen your post Abe.
    We have some 5 Master Cella's installed last months, so if any problems, fire your questions Abe.
    But, my son knows them better then I do
    Apr 2001
    2,099
    27
    I got it all working, it looks good.
    The light is connected to AUX relay 2, to switch the light on you keep the button pressed for 5 secs.............then it switches!!
    The programming part , I managed, only wished that the manual would explain the sequences better, in a flow chart, instead of having to squint reading small print.....
    Peter.
    I say I managed to set the parametres, to gain access to set parameters you press prg and set simultaneosly for 5 secs.
    Then it shows 00 on screen
    You press up /down buttons until you reash password which is 22.
    Then you press SET.....
    Now you can change settings
    First is, HACCP which are the probe parameters, which I dont touch
    I wanted to go to modify the next set, which are COMPRESSOR
    Its got all the stuff in the manual, but its small and not clear cut. The sequence should be in big bold and in flow chart form.
    The sequence is I think.
    scroll
    When you reach the desired parameter
    Press SET
    At this stage I gave up..............because the manual gets all muddled up..............
    I will write it up later this evening so u understand what I mean
    This is where I was having difficulty.
    Apr 2001
    2,099
    27
    Heres a pic of the controller and room
    Just showing off my new casio digital camera!!
    Dec 2004
    Australia
    52
    519
    G'day Abe.
    This is the sheet I use for Carel controllers.
    It is written in Australian, might be harder to understand than Greek
    Apr 2001
    2,099
    27
    Temp
    I cant see it
    Dec 2004
    Australia
    52
    519
    Sorry Abe.
    This might be a bit better.
    Dec 2004
    Australia
    52
    519
    No thats not any better either...
    Well it is a handy sheet when it can be read
    Cant seem to resize the picture big enough to read.
    Sorry Abe.
    Apr 2001
    2,099
    27
    its ok Temp
    No worries mate
    Brian sent me a very useful link which I have printed off
    Thanks for helping anyways
    vinyljedi's Avatar
    vinyljedi Guest
    hi first time ive used this system but i have one problem. in the manual the time for defrost says 8 ORE, can ne1 please explain wat ORE stands for
    cheers
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by vinyljedi View Post
    cheers
    Ore is Italian word for Hour!
    Jul 2006
    uk
    11
    hi have had same problem , wired into aux 2 , but but still no light , what par have to be set at for light
    nick
    Jul 2006
    uk
    11
    hi nick again ,light is on all the time except on defrost ?
    Oct 2003
    5,630
    34
    Vinyljedi, thanks Nike123.
    Will this be your only post here, even no introduction?
    Jul 2006
    uk
    11
    hi again , realy do need help , handing over tomorrow , and yes feel dum , simple light not working
    regards nick from a wet cornwall
  19. #19
    11,024
    Nick Clark, a specific question might get an answer.
    So far you said that the light won't switch on, then you stated that it is on all the time except during defrost.
    We don't know what you want so I'm sorry it is difficult to answer.
  20. #20
    greyhound's Avatar
    greyhound Guest
    Wink Re: New Carell Control Panel
    Quote Originally Posted by Abe View Post
    Peter.
    scroll
    Press SET
    next time use a peco expert.it is clear and simple.and does exactly what it says on the tin.
  1. Replies: 21
    Last Post: 05-07-2008, 10:48 AM
  2. Control scenario
    By Mike Hopkins in forum Technical Discussions
    Last Post: 14-09-2007, 11:25 AM
  3. Control Panel
    By Abe in forum Electrical
    Last Post: 21-06-2004, 08:45 PM
  4. New Capacity Control Solution
    By embrown in forum New Technologies
    Last Post: 30-12-2003, 01:33 PM
  5. Pego Control Panel
    By Abe in forum Trouble Shooting
    Last Post: 24-10-2001, 07:22 PM
