Thread: heat exchanger material issue
11-08-2006, 02:20 AM #1
Hi Sirs
As we know, the copper price is rising. it makes HVACR manufacturer's cost increase. Most air heat exchanger is made of copper and aluminium. Is there any innovative tech to find alternatives for this situation? I've read some article for plastic pipe heat exchanger in refrigeration field. How do you think the use of plastic HX in HVACR industry? is it a way to save expensive metal like copper,etc?
welcome your input
regards
LC
19-08-2006, 07:06 PM #2
Re: heat exchanger material issue
Hi LC,
To be very honest this is the first time I heard that plastic heat exchangers are being used in the refrigeration field. Could you please give some reference of the document where you had seen such.
I shall try and do a bit of work on what you have said as there should be some alternative to copper and aluminium in the field of refrigeration.
With best wishes, Samarjit Sen
19-08-2006, 11:29 PM #3
I have heard of some ceramic heat exchangers I believe. Some of this same material is being used for superconducting wire.
Now if we could only get high temperature superconducting material for heat exchangers. Think about this, if the material resistance goes to zero, the heat transfer should be very good.
21-08-2006, 02:19 AM #4
pls refer to http://www.powercold.com to see Nauticon fluid cooler product.
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM -
Heat exchanger company ACP
By JKProSoft in forum Legal-Business-MarketingReplies: 5Last Post: 22-07-2006, 11:37 AM -
heat exchanger design
By Lc_shi in forum FundamentalsReplies: 33Last Post: 13-03-2006, 09:57 AM -
R134a <-> liquid heat exchanger design
By DaBit in forum Technical SpeculationsReplies: 19Last Post: 10-05-2002, 08:36 AM -
Restricted Heat Exchanger
By Abe in forum Trouble ShootingReplies: 1Last Post: 28-10-2001, 10:18 PM
