Thread: Diplomat 6528 Fault Code
09-08-2006, 08:11 PM #1
All
I'll be honest from the start and tell you that I am an engineer but not a refrigeration engineer.
I've got a problem with our Diplomat 6582 fridge and the manual tells me that the flashing LED's indicate a fault code, but does not tell me what the particular fault code means . The book says "call service"!!
The red fault button LED is flashing as is are the green 4 and 7 degree LED's.
Just wondering if anyone can help please as I called the number in the back of the instructions and they want £90 for the call out before they start!!
I've scoured the internet with no success - very frustrating.
T
09-08-2006, 10:51 PM #2
Re: Diplomat 6528 Fault Code
Hi T and welcome.
I've tried searching on
http://www.ukwhitegoods.co.uk
as well but didn't get much luck either. Interesting bit on 'fault codes' though which indicates that they are not too specific regarding the fault; more to give an area to look at...
Have a look at the above site, you might find a local service man who will give you a fairer price, the manufacturer will always charge more.Brian - Newton Abbot, Devon, UK
31-10-2006, 04:21 PM #3
Can you be more specific?
I don't know this refrigerator model but if you can tell me the type (freezer, fridge-freezer ), electronic control with sensors or just mechanic thermostat and the flashing led it's just a signaling system.
31-10-2006, 07:43 PM #4
Check the date N.D. and note that tbis poster did not return after his one post.
LG Fault Code
By Abe in forum Air ConditioningReplies: 5Last Post: 26-09-2009, 09:04 AM -
Daikin fault codes
By Markie in forum Air ConditioningReplies: 16Last Post: 13-01-2009, 01:58 AM -
split a/c fault code
By ksvinod in forum Air ConditioningReplies: 1Last Post: 04-07-2007, 02:12 PM -
Fault Code Sheets...?
By C_Henderson in forum Air ConditioningReplies: 2Last Post: 01-08-2006, 05:19 PM -
Fault Code Library
By frank in forum Air ConditioningReplies: 7Last Post: 12-12-2005, 02:19 PM
