Thread: Liquid line increase
27-07-2006, 08:06 PM #1
While looking at large cold room with 3 blowers supplied from 3 carrier condensing units,I noticed the liquid lines went from 5/8 to 7/8 about .5 meter after sight glass.Is this ok.
Regards Bernard
27-07-2006, 08:55 PM #2
Re: Liquid line increase
I dont see any reason why not. a system with an excessively long pipe run could have the tubing oversized to compensate for any pressure drop involved.
Takes a licking, keeps on ticking.
27-07-2006, 09:05 PM #3
Hi Bernard,
I doubt the difference in sizes will present any problems. When I did a lot of supermarket work I routinely over sized the liquid lines, and insulated them in areas where the piping ran through a warm space.
The larger piping allows a lower pressure loss in the liquid line. That helps a lot. Secondly, if the liquid line runs through a space with an air temperature lower than the liquid line temperature, that also helps.
If the liquid line runs through a warm space, the liquid line can absorb heat, which does not help you. In fact, it can decrease the system capacity.
27-07-2006, 10:24 PM #4
Yes the pipe runs are long so thats the reason,another question the condensers were large but the recievers small.You would never be able to pump them down.Sorry I don,t have much info on the system and they were running fine.But should the receivers not be sized to cope with the liquid in the system.
Thanks Bernard
27-07-2006, 11:52 PM #5
Originally Posted by bernard
I would question why the receiver is so small, unless it was intended for a close coupled system.
Suction gas <-> liquid line heat exchange and performance gains
By DaBit in forum Technical SpeculationsReplies: 30Last Post: 18-05-2010, 01:52 PM -
liquid line sight glass mystery
By austech in forum Technical DiscussionsReplies: 19Last Post: 18-07-2006, 08:16 PM -
Liquid line for multi evaporators
By Kevin Yeo in forum Supermarket RefrigerationReplies: 1Last Post: 29-12-2005, 02:29 PM -
Parker levels in ammonia systems
By Friobernal in forum IndustrialReplies: 3Last Post: 04-08-2005, 03:46 PM
