Results 1 to 2 of 2
Thread: Ground source heat pump
25-07-2006, 12:22 AM #1
Evening Gentleman. I hope some of you learned people can help me. I have been looking these heat exchangers by alpha laval for a home made system.
http://www.alfalaval.com/ecoreJava/W...4&languageID=1
I hope to base the design on Viessmanns design guide which gives information on GSHP design.
I would appreciate if some of you chaps could tell me the correrelation between evaporator and condensing PHE sizing for a water to refrigerant application.
The project is for a highly insulated new build with 2 floors. The heat loss is about 8.8KW per floor.
Viessmann,s gives detailed information for their Vitocal 300 which has a refrigerant capacity of 8.4 KW @ brine inlet temperature of 0 C and a heating water outlet temperature of 35 C.
Many Thanks.
29-07-2006, 08:51 PM #2
Re: Ground source heat pump
Help ,anyone please .
dual source heat pump
By Lc_shi in forum New TechnologiesReplies: 29Last Post: 12-08-2010, 02:24 AM -
frostles heat pump
By Lc_shi in forum New TechnologiesReplies: 27Last Post: 31-03-2008, 07:53 AM -
Air Source Heat Pump - temp of refrigerant leaving evaporator
By anup in forum FundamentalsReplies: 3Last Post: 06-11-2006, 05:04 AM -
By Lc_shi in forum Refrigeration BooksReplies: 7Last Post: 18-04-2006, 04:30 PM -
water source heat pump
By Lc_shi in forum New TechnologiesReplies: 12Last Post: 29-03-2005, 09:09 PM
