23-07-2006, 11:14 AM #1
Hello To everyone need some advice
I have a nine year old Zanussi ZFC 61/27 Single compressor Fridge Freezer Which has developed a problem with the fridge compartment it is too warm lowest temperature achieved is 5.8 oC The freezer is -24oC Can anyone give me some advice on how to sort this problem out. PS Ice does form on the backplate of the fridge.
23-07-2006, 11:36 AM #2
Re: Hello To everyone need some advice
Me thinks the efficiency of the compressor is reducing, hence noticeable in fridge compartment which is the last section of evaporator surface.
A Fridge technician requires to check pressures via some access port, if fitted.
23-07-2006, 01:09 PM #3
Thanks for the info
24-07-2006, 12:14 AM #4
Firstly defrost the unit for 24 hours, then if still have a fault after 8 hours of running time ........
If its an R12 unit, then time to replace it.
IF its an R134a unit, make sure the door seal is good,then if still faulty i would recover the old refrigerant and purge nitrogen free oxygen through the system, (checking for blockages), change the dryer and recharge the unit with R134a.
maybe change the compressor at the same time,
should cost around £150 (new comp)
hope this helps
Your advice to Split Air buyers.
By mick2me in forum Air ConditioningReplies: 5Last Post: 15-07-2006, 04:59 PM -
Good advice!
By shogun7 in forum Chit Chat & Service StoriesReplies: 0Last Post: 03-09-2004, 01:06 AM -
Help, advice needed.
By josewick in forum Trouble ShootingReplies: 20Last Post: 30-10-2003, 09:27 PM -
Any advice how to cure this blocked system?
By moh in forum Trouble ShootingReplies: 8Last Post: 25-06-2002, 08:35 PM
