Results 1 to 2 of 2
    Horatiu's Avatar
    Horatiu Guest
    Dimethyl Ether as a refrigerant
    Hello everyone!
    I know that Dimethyl Ether (DME or RE170) can be used as a refrigerant. The main disadvantage of DME is its exlopsivity and the main advantages are 0 ODP and 2 or 3 GWP .Theoretically it can be used only in very small refrigeration plants. Do you actually know or heard about someone really using it?
    Aug 2005
    5,302
    Re: Dimethyl Ether as a refrigerant
    Here is another twist on the same subject:
    R-723
    composed of (60%) Ammonia & (40%) Dimethyl ether (% on mass basis)
    http://www.eurammon.com/englisch/dow...rammon12en.pdf
    This is the only application I have heard of where dimethyl ether is used. At least in the last 50 years or so I am aware of.
  1. R600 Refrigerant.
    By tonydeith in forum Refrigerants
    Last Post: 21-04-2011, 08:52 AM
  2. CARE refigerants by BOC
    By dogma in forum Refrigerants
    Last Post: 23-03-2010, 12:39 PM
  3. Ether or Ester?
    By Daddy Cool in forum Air Conditioning
    Last Post: 29-04-2006, 03:08 PM
  4. Liquid refrigerant and bubles in sightglass
    By aygul in forum Trouble Shooting
    Last Post: 30-08-2003, 09:07 PM
  5. Refrigerant Reclamation
    By herefishy in forum Commercial
    Last Post: 23-07-2003, 08:19 AM
