Results 1 to 15 of 15
Thread: carrier zephyr 200
10-07-2006, 07:06 PM #1
carrier zephyr 200
need wiring diagram for truck refrigeration system
Carrier Zephyr 200
10-07-2006, 09:35 PM #2
Re: carrier zephyr 200
Originally Posted by diene
Hi Diene send me your email via pm as I have the wiring diagrams you need
Martin
11-07-2006, 07:00 PM #3
Hi info sent
Martin
12-07-2006, 05:26 PM #4
hi martin
got the zephyr 200 diagrams.thanks.
after few minute from start the control box
start cycling (getting crazy).
what could be the problem?
12-07-2006, 07:14 PM #5
Martin
13-07-2006, 11:41 AM #6
hi martin
yes the display goes on and off
and both the clutch and evoparetor fan goes off.
thanks.
13-07-2006, 07:01 PM #7
Hi check the main 40 amp fuse(it should be around the battery) in not corroded or the main wiring to the unit
With a multi meter see if the power is dropping away as soon as the load is put on the system ie fans & clutch etc
Have fun
Martin
13-05-2008, 11:41 PM #8
CIAO,
PER FAVORE AVREI BISOGNO DELLO SCHEMA ELETTRICO DEL CARRIER ZEPHIR 200 SE PUOI AIUTARMI.
GRAZIE, LA MIA EMAIL è Fryend76@hotmail.it.
ciao
13-05-2008, 11:42 PM #9
CIAO,
ciao 13-07-2006 06:01 PM
18-10-2008, 11:06 PM #10
18-10-2008, 11:07 PM #11
31-01-2009, 07:15 PM #12
Dear friend,
I desperatly need electrical wiring diagram for Carrier Zephyr 200, cooling system. Please send me a copy via e-mail if you are in position to do so. thanks in advance
Aleksandar
e-mail: dugalix@gmail.com
21-07-2009, 12:43 AM #13
Hi Martin, can you please also send me the wiring diagram it would be of great help to me!
Thank you in advance
27-08-2010, 03:57 PM #14
I have problems with Carrier Zephyr 200 and I need the wiring diagram. Thank You in advence.
e-mail : mongoor@hotmail.com
28-10-2010, 07:19 PM #15
Hi Martin!
Please send me also the wiring diagram and pherhaps the operation manual for the zephyr 200!
Big THANK YOU from Austria!!!
Ps: If anotherone can help me, please send it to me!
kamikaze@aon.at
carrier fault codes
By richelli in forum Trouble ShootingReplies: 5Last Post: 18-06-2010, 07:35 AM -
Carrier Water Chillers
By Latte in forum Air ConditioningReplies: 10Last Post: 11-10-2008, 08:43 PM -
Carrier chiller oil migration
By lowtech in forum IndustrialReplies: 5Last Post: 30-04-2006, 04:11 PM -
carrier remote
By superswill in forum Trouble ShootingReplies: 2Last Post: 26-04-2006, 09:17 PM -
carrier controlers
By coolflow in forum Technical DiscussionsReplies: 2Last Post: 12-01-2006, 08:26 AM
