Thread: MitsubishiP5
08-09-2023, 04:23 PM #1
MitsubishiP5
Hello,
i recentley took advice on here on how to deal with a P5 error code on a mitsubishi air con unit. I have emptied both bung plugs of the water and reattached the panels.
It worked for about 45 minutes then just shut down again.
Flashing P5 then 02?
Any help would be much appreciated as it is warm as here in the bar
thanks
Paul
09-09-2023, 07:22 AM #2
Re: MitsubishiP5
have you removed and cleaned the drip tray and have you checked the lift pump is working
