    Mar 2008
    Australia
    7
    Westinghouse BJ425t playing-up
    I've got a 20 year old Westinghouse BJ425t Fridge/Freezer. It recently iced-up and now I have to manually defrost it every 2 days or so.
    Previously when it was working I would occasionally hear it performing the defrost function. I could hear drops of water hitting the heating element and making a hissing sound. At a guess I would say it did this once a day.
    I was hoping that the defrost element was blown, because I would be able to replace that myself. I took it out but it is showing 120 ohm resistance so I think it is still good.
    Sadly, immediately after I did the job of removing the defrost element, the fridge compartment no longer kept cool. I discovered the fan had been slighly fouled and now the fan appears to have failed completely (infinite ohms).
    I have a new fan, but before I installed it I tried to figure out the important wiring and could make no sense of it.
    I opened the back and took a look at the PCB.
    There are a bunch of 7 thicker (eg power) wires from the PCB to the inside
    brown, blue, green/yellow which presumable is active, neutral and earth
    RED, PINK, WHITE, BLACK
    The red and pink also come off the PCB and have a connector which is easily accessible at the back. What would this be?
    Can someone please help me with a circuit diagram for this fridge, or a service manual for Westinghouse fridges circa 2003?
    Mar 2008
    Australia
    7
    Re: Westinghouse BJ425t playing-up
    As I mentioned, there is a 2-pin service port at the rear of the control box.
    One of you experts must know what that is for.
    Feb 2011
    scotland
    384
    Not an expert.
    Dont have a diagram.
    But,
    Maybe its a two speed motor.
    Maybe its a safety circuit.
    Maybe its a thermistor. ?
    I take it the old fan is different from the new one?
