Results 1 to 2 of 2
    May 2023
    Austin, Texas
    1
    Mini split lineset lenght
    I have a small apartment, the only place to mount the mini split condenser unit is about 6 feet away from evaporator. The unit is 12,000 BTU. Manuel says I need at least 10 feet of lineset. I was advised not to leave excess linset coiled behind the unit. Could I run the lineset in a serpentine pattern on the wall behind the condenser, to gain lineset length?
    Oct 2003
    5,630
    34
    Re: Mini split lineset lenght
    Just reclaim some gas ..
