    Jun 2020
    Malaysia
    44
    Drinking water and copper
    Dear Friends,
    I have a question. Using copper pipe (as evaporator) inside of drinking water steel tank for cooling drinking water is correct ? or using copper metal in drinking water tank is dangerous for health (as result of cuprous oxide) ??
    Thanks for sharing your knowledge in advance.
    Sep 2009
    Iran
    66
    672
    1
    Re: Drinking water and copper
    Copper in drinking water isn't good for health.
    Also steel is a same.
    It should be stainless steel jar
    You can put Copper behind the stainless steel
    And water inside of jar.
    Or use both of them stainless steel.
    Jun 2020
    Malaysia
    44
    Thanks MBC for your reply.
    I heard in USA and some other countries all of water pipes made form copper, Isn’t it ? It means it is very dangerous if someone wants to drink water form this pipes ?
    Sep 2009
    Iran
    66
    672
    1
    Yes
    In Australia and in New Zealand in old buildings they used copper pipe for cold and hot water.
    But in some countries it is forbidden.
    Jul 2006
    73
    865
    Copper is used in homes here and is probably the first choice, although not used as much as is was because of the expense. PEX is used mostly now because of the lower expense for Labor and Materials.
    When Copper is used now you must use Lead-Free Solder and Non-Corrosive Flux.
