Results 1 to 2 of 2
    Sep 2005
    42
    191
    evap fan speed control?
    there's plenty of info/talk about condenser fan speed control, inverter driven compressors etc..
    but I never see anything about evap fan control on commercial stuff?
    small split air con units are the only thing I can think of that controls evap fan speed
    I've been thinking about this for a while... as long as liquid and suction pressures are within range you could (pretty much) just use room temperature to control evap fan speed?
    evap capacity is pretty much just linked to air on temp
    so as room temp drops, why not increase fan speed?
    Sep 2009
    Iran
    66
    672
    1
    Re: evap fan speed control?
    I done it .
    It was confection ( gummi candy -- strach mold )room
    To dry it
    Evaporators Surface area about 4 times
    It has 2 Condenser one in the room and another one on the roof with actual capacity
    Room's Condenser ( to cover cooling comes from Evaporators) with temperature control's for using desuperheat
    Room temperature about 32 c
    Evaporators has speed control's for fans
    Room has extra circulation fan to remove humidity form gummi and strach molds
    In winter time we had heating system ( steam Coil )
    Also Compressor has a crankcase presuure control's to protect that .
