Results 1 to 2 of 2
21-09-2022, 10:38 PM #1
Tk sb210 with high head and suction pressures after compressor replacement
I got a thermo king sb210 with high head and suction pressures after compressor replacement . Rebuilt 3 way valve and clean Debris out of Discharge line to 3 Way Valve . Also replaced Drier with Compressor.
Got 65 psi Suction and 400 psi Discharge and only -8 temperture differential.
Any Thoughts ?
Reed plate on 1 Piston was Gone . and had Pieces in 3 Way valve Screen
ThanksLast edited by MMCDONALD; 21-09-2022 at 10:50 PM.
28-09-2022, 10:58 PM #2
Re: Tk sb210 with high head and suction pressures after compressor replacement
checked the txv?
