Thread: convert to R290
    Sep 2005
    42
    191
    convert to R290
    I'm having a whole bunch of freezer systems moved from old freezers to new
    they almost all run on R404a
    talked to engineer about swapping to a different gas now, the thinking being r404 will be harder and harder to work with in the future
    we pondered about r290.... condensing units are all outside in fresh air, short pipe runs to evaps, would need to swap to explosion proof lights inside the freezers and add alarms
    but... there doesn't seam to be a lot of that going on?
    reluctant to switch to another gas now that will be phased out later on
    if we swapped a few systems over now, could recover the 404 and save it for the other systems later on
    can't see a lot of info about r290 in older scroll compressors?
    anyone have any ideas/input?
    Feb 2008
    505
    21
    Re: convert to R290
    you need to check if compressors are suitable to run on R290 you will need spark proof electrics also volume of room needs to be calculated to check maximum charge of refrigerant that you can have in the system. there are other refrigerants you can convert to that might be easer
    Sep 2005
    42
    191
    Re: convert to R290
    I'm wondering which other gas I can retrofit which will give a decent capacity and be around for a long time?
    r290 is the only one I can think of?.... have to assume there'll be a steady purge (hehe) of refrigerants
    spark proof electrics are no problem, have some experience with that stuff
    didn't think about volume of the room, that might be a problem, rough 1700cubic feet (about 50 cubic meters) and 3 seperate systems with a bit over 10kg of gas in each
    well... they had ~10kg of r404 in them, I think charge is noticeably lower with r290 ?
    Feb 2011
    scotland
    451
    Re: convert to R290
    Units outside cooling brine, and pump the brine to the rooms?
    Units outside cooling CO2, and pump liquid CO2 to the rooms?
    Sell the old kit and use the money to buy units or a chiller that runs on a natural refrigerant?
    May 2012
    59
    1,528
    36
    Re: convert to R290
    You might want to look at.
    Page 7 has your limits.
    https://www.logic4training.co.uk/wp-...Guidelines.pdf
    It's from ACRIB.
    Rob
