Results 1 to 1 of 1
27-06-2022, 08:09 PM #1
i look the value in watt of smd resistor in series with ptc thermistor in fujitsu
hi on the above aircondition inverter had burnt the smd resistor 0R0 (0 ohm) wich is in series with ptc thermistor for inrush current of power bridge rectifier from the output charge the two big electrolytic capacitors 320 volt dc
the bridge rectifier is 25 ampere for thermistor ptc i cant find technical manual is ZPR0RCH400
Can you tell me anybody the right watt of this resistor or maby can i replace it with a right value of smd fuse ?
or is not necessary to use this fuse
i mean and thermistor thermal fuse is not ?
