Results 1 to 13 of 13
Thread: IOT on HVAC-R
    Mar 2022
    Brasil
    1
    IOT on HVAC-R
    Hello fellow professionals. I am an industrial refrigeration technician and automation engineer working on a company. I currently reside in Brazil and I created an IOT product for refrigeration equipment in general. It collects data from equipment in real time and sends it to a server where an AI analyzes the data and based on the experience it has created, issues a fault diagnosis. Currently it has been working well in split, self and rooftop equipment. And now I want to move it to chillers, which creates a new scenario for me in which chillers have more complex behaviors and a variety of equipment configurations. Whoever is interested in the project and wants to discuss it or likes IOT I am open to hear tips and criticisms.
    Big hug to all.
    Data on the project:
    Resume:
    The hardware monitors variables such as temperature, current and voltage of the equipment, sends the data over the internet (WIFI) where the AI ​​issues a diagnosis with 80% accuracy and 7 days in advance through a mobile APP.
    How long to install: 3 hours on average
    How many sensors: 7
    Consume of data: 1mb hour.
    Sep 2005
    41
    179
    Re: IOT on HVAC-R
    ok... I know this is a spam thread....
    but if anyone is interested in this stuff just ask some questions, I'm running an esp32 board (same family as the picture above) and have 20 temp sensors connected to it reporting back via wifi
    I'm about to add current and power sensors to it
    pressure sensors look easy but I don't think I'll bother
    board plus temp sensors set me back about £20
    74
    11,181
    58
    Re: IOT on HVAC-R
    That looks like a useful piece of kit and at that price it's got to be worth a try.
    Edit: not actually designed as a spam thread but our Josip got hacked and was being used by some oik from far off lands.
    ireland
    52
    1,430
    Re: IOT on HVAC-R
    no brainer at that price @knighty, fair play to you for getting it set up. Would you have any guidance/advice for someone not too proficient with this stuff for doing what you have put together?
    Sep 2005
    41
    179
    Re: IOT on HVAC-R
    I bought some ESP32 boards like these...
    https://www.ebay.co.uk/itm/304561797507
    temperature sensors like these...
    https://www.ebay.co.uk/itm/111434870374
    and isolation boards like these
    https://www.ebay.co.uk/itm/362990277340
    easier than me writing it up, here's an online guide
    https://randomnerdtutorials.com/esp8...h-arduino-ide/
    I haven't added the mains power boards yet, I'll come back and update tis when I have
    the temperature sensors are really cool, they have a chip in them which can talk to the ESP32 board, so you wire all the temp sensors in parallel.... negative wire, 5v wire (to the 5v on the board) and a daa wire (all data wires joined together)
    May 2012
    58
    1,508
    35
    Re: IOT on HVAC-R
    Quote Originally Posted by knighty View Post
    Very interesting.
    Whats the legality of putting all the bits together in a functional box and selling as a unit?
    Would you be allowed because of licences or other patenting requirements.
    Could the monitor be converted to a controller?
    Rob
    Sep 2005
    41
    179
    Re: IOT on HVAC-R
    Very interesting.
    Rob
    it's all open source, so you can do (pretty much) whatever you like with it
    lots of the expensive systems that you see are based on the same board and sensors
    there's loads of options for the controller boards... they can do all sorts, and they're used in all sorts of things already - I have LED colour changing bulbs which are based on the same system
    Sep 2005
    41
    179
    Re: IOT on HVAC-R
    bit of an odd one here.... I'm setup reading evap temp, air in temp and air out temp...
    but there's hardly any difference between air in and out temp?
    one freezer right now says...
    -20.9'C evap temp
    -15.1'C air in temp
    -15.3'C air out temp
    used as a blast freezer so -20evap and -15 air in sounds about right to me?
    am I using the wrong type of temp sensors? https://www.ebay.co.uk/itm/111434870374
    I'll pull all 3 temp sensors and drop them into a cup of water to calibrate them, make sure they're all reading right.... but I had 10 running on the bench and they were all within 0.5'C on the bench - I took that as fine because they were spread out a bit etc..
    there's plenty of evap airflow there
    condenser is tossing out plenty of heat
    ireland
    52
    1,430
    Re: IOT on HVAC-R
    If it's a blast freezer, small compartment? If so may need warm product in place to see wider delta T
    Sep 2005
    41
    179
    Re: IOT on HVAC-R
    box is the box from the back of a truck, 27ft long 8ft wide, about 8ft high
    evaps are standard freezer evaps - calling it a blast freezer is using a bit of poetic licence :-o
    it's nice to see graphs of what's going on.... here's air on / evap / air off temp probes for 2 boxes yesterday
    one freezer made it down to set point so you can see it cycle on and off, other one never got that low
    I think my evap probs are badly places... too close to the incoming air so that's throwing the reading off?
    I need to add an extra temp prob at the other end of the box to use as room temp - or at least a probe somewhere out of the airflow
    graphs/numbers etc/ will really help me trouble shoot problems in the future and find them before they cause trouble
    colour changing bulb is up and running.... but different shades of blue are too hard to tell apart... I'll change it to stick with full colours and change colour instead, so red/yellow/orange/blue/green
    Feb 2011
    scotland
    232
    13
    Re: IOT on HVAC-R
    Any ice on the evap coil? front face, back face, inside the coil.
    All the fans running, and blowing air in the right direction?
    Suction superheat ok?
    Sep 2005
    41
    179
    Re: IOT on HVAC-R
    everything is running great, good airflow, no ice build up
    just the evap probs are reading too high, I think they're too far on the incoming air side, so that incoming air is throwing the reading off
    it doesn't really matter, I'll push them in a bit further, they're only for a rough guide
    could always fix them to the a coper pipe at the end of the evap instead
    Oct 2001
    Nottingham UK
    5,556
    49
    Re: IOT on HVAC-R
    How do your temp readings compare to a normal thermometer reading ?
Tags for this Thread
